Originally posted by gsdanno1
View Post
The extra was IF the seal hung up on the powerhead coming out..
**The seal, the hard part should be installed into the "engine part". The sealing surface doesn't touch anything UNTIL IT'S INSTALLED, IE the shaft/crank/pump...
Just like automotive wheel bearing seals... They get installed into the hub FIRST, and then seal over the shaft..
