I always seem to do things backwards , I just added new gear oil . will drain . Speaking of oil , I still have an oil leak from the oil pump area. there was no leak when I started all of this work. I've replaced the oil pump, o rings ( twice) , and the leak is still there WTF . I've pulled the power head 3 times at $100 a pop for the gasket , I am really at my wits end . I have a compressor and mityvac to do the vacuum and pressure tests ( I can regulate air down to about 5psi), but no way to submerge to look for bubbles . I'm thinking a spray bottle of dawn around the drain plugs , water pump seals , prop seals will show some bubbles
access to oil pan
Maybe you can borrow a mity vac to pressurize the lower unit. Make sure the two drain screws aren't leaking any pressure. Seals are not too bad.
I would run it for few hours, normal use, in water,
under load. Keeping an eye on the engine oil level of course. Then see if the damn thing is still leaking. Assuming all the seals are oriented correctly. And speedie sleeve is good. Who knows? Screw the EPA...
I just read that you have a pressure tester, good.
Supposed to hold 10 lbs for 10 seconds. Mine held for 45 seconds, then I released the pressure.
Wonder what Rodbolt has to say about the engine oil leak?Last edited by pstephens46; 02-26-2017, 01:40 PM.
Never pressure tested a lower unit in all the years I've been at it.
Change your fluid on a regular hourly schedule. If fluid looks good, fill er up and go. If not so good, reseal lower unit, like in ALL the seals.
Yamaha orientation of the oil seals is bogus, exposes the outside seal garter spring to raw water, no good for longevity. Back to back like other manufactures suggest is the way to go. Or maybe you can pack the recessed garter spring area with grease.
My outer seal garter spring fail (other seal was fine) and I had NO water intrusion.Originally posted by scofflaw View PostNever pressure tested a lower unit in all the years I've been at it.
When the WP is off, it doesn't take 5 seconds to remove the cover and see if the garter is gone or not...Scott
Should not fail in 200 hours, somethin else is killing it. Pack it in grease thenOriginally posted by TownsendsFJR1300 View PostMy outer seal garter spring fail (other seal was fine) and I had NO water intrusion.
The seal was about 7 years old at the time (original 2006 engine)...Originally posted by scofflaw View PostShould not fail in 200 hours, somethin else is killing it. Pack it in grease then
The shop I used stated it was way over due for inspection and it was not un-common for it to fail just over TIME. Sure enough, the spring failed...
There's nothing else in there that can "kill" the spring, short of salt water, Yamaha's design of exposing the spring, then putting a cover over the seals(helping keep salt water in there-and probably keeping flushing water OUT).Last edited by TownsendsFJR1300; 02-26-2017, 07:36 PM.Scott
I got all the old parts back when they replaced it and do have the lower, original spring which is fine.Originally posted by scofflaw View PostProbably not a bad idea just to replace the spring when the WP impeller is done
But I agree, that would be the simplest, easiest, preventive thing to do. Next time, it'll be changed (the spring from a brand new seal).
I expected it to be broke when I just did my WP. Although it was fine, there was lots of crap above the seal and under the cover. What it was, I don't know-looked like loose grass, crap that might be floating in the water. It certainly didn't help water evaporate from atop the seal. (It was 3 years since the last WP).
Worse yet, the master tech put sealer around that round cover (which is NOT needed.. ???)
With that said, I just machined down a fitting from a spare LU oil pump (that screws on your quart)(same threads as the LU) so I can hook up my Mity Vac. I just have to pick a gauge...
**** I saw last week (and can't find it now), of a small circular "ring" that replaces the garter spring altogether. It keeps tension on the seal and of course, won't rust out / fail. It simply replaces the spring.Last edited by TownsendsFJR1300; 02-26-2017, 08:08 PM.Scott
Spring has to be stainless for obvious reasons. I saw a YouTube where the spring was replaced with a nitrile ring.
Towards the end of this video:
https://m.youtube.com/watch?v=c14ixpVXrZ0Last edited by pstephens46; 02-26-2017, 10:39 PM.
That's it!!!! It was that video I tripped up on.Originally posted by pstephens46 View PostSpring has to be stainless for obvious reasons. I saw a YouTube where the spring was replaced with a nitrile ring.
Does anyone have any experience with it?
Rodbolt, your thoughts?Scott
Originally posted by scofflaw View PostProbably not a bad idea just to replace the spring when the WP impeller is doneIt would never have occurred to me to do this.Originally posted by TownsendsFJR1300 View PostNext time, it'll be changed (the spring from a brand new seal).
"Eventually" the rubber itself must get brittle and wear - but in the meantime -
fast and easy to possibly "extend its life" for a few years
(I see Worst Marine stores have the seal under the Sierra label for $5.23)
