I have an '03 200 HP 4 stroke on a Hurricane 237SD. There is an intermittent problem where the engine cuts out when I hit the trim button. I've replaced battery cables, battery switch and had the ignition switch and trim switch checked. At first the motor would stall at low speed and not start right back up. After work was done on it, it only seems to happen a high speeds and the motor doesn't stall but you feel the power loss and power returns when the trim switch is off. Trim relay has not been replaced yet. Mechanic says it's a $300 part.
Thanks for any help....
