neutral safety switch
    All the passenger would have had to do is turn the key to the off position. I suspect he knew nothing about an airplane and was traumatized by what was going on. And lost his mind.
    He could have also simply applied the brakes.
    Mmm, so killing the plane's engine was as easy as turning key off. My guess is after the incident the pilot had asked the passenger the same question. The passengers answer was probably something like, "i didn't know I was allowed to touch anything". The passenger was the pilots girlfriend, btw. Not to imply anything about females in the that particular scenario. But you know, their brains work differently in traumatic situations.
    Jason
      I think it said something about a girl friend in the run away plane, but could be wrong
        Yes and it was also said she was taken to the hospital due to being in such a state of shock. Medical care was a little different a few years ago.
        • #19
          Let's not blame her. Blame the dummy who didn't set the brakes! He was so distracted that I wonder what she looked like?
          • #20
            What do you mean by traumatic situations? Is a normal every day occurrence traumatic for the other gender? My wife and I are definitely not from the same planet. I can't get her to take the wheel of the boat. A six year old boy would be fighting me to take the controls.
            • #21
              Speaking of brakes, there are toe brakes and heel brakes in airplanes. Depends upon the model.
              I can say first hand that a Taylor Craft airplane does not have toe brakes. It has heel brakes. On the pilot side only.
              First time I got in one I started to taxi for a familiarization flight with my buddy, who had flown one, in the co-pilots seat. Needed to brake and make a turn. Had never flown an airplane with heel brakes before. Toe brakes only. Think I could find them? Hell no. Buddy kept saying you better get us stopped, while I frantically tried to find and apply the brakes. Put the nose of the airplane about six inches from a taxiway sign before I could find the brakes and get the airplane stopped. Buddy had to get out and pull us backwards so that we could clear the sign.
              Lesson learned. Most (all) of my learning has been via my mistakes. Hopefully no one got hurt and nothing got damaged in the learning process. Not that I haven't hurt myself and damaged some stuff along the way.
              • #22
                How about simply tying off a cleat? Nope. Starts every single time by making a loop and trying to shove it through the middle to then try to create a KNOT on top of the damn thing. My son got it the first time I demonstrated.
                • #23
                  Surprised at you Boscoe, younger years I guess. Didn't you guys use your Pre-Flight Inspection check list?
                  My younger years were spent flying around in my best friends N8523U, 1964 Cessna 172F Skyhawk. Never had a pilots license, only flew right seat. Checked the tail # and it is still in use today
                  Here's the Pre-flight check list for it.
                  [IMG]C172 by Charles Postis, on Flickr[/IMG]
                  Too bad boat fuel tanks don't have a sump and drain line to draw and check our fuel for contaminants like aircraft!
                  Guess during the age of that video they didn't have many check lists?
                  Chuck,
                  • #24
                    What is a check list? We don't need no stinkin check list.
                    • #25
                      Chuck, missed one in pre-flight....
                      • #26
                        OK! Is that rum in that coke bottle in this pic:
                        [IMG]C172Crash by Charles Postis, on Flickr[/IMG]
                        Chuck,
                        • #27
                          No blame on the passenger whatsoever. My statement was whether or not something could have been done by the passenger, not that it was his/her responsibility to do anything. Big difference.
                          Jason
                          • #28
                            Perhaps it should have had a neutral safety switch?? That is what the post is about (I think)
                            • #29
                              even a neutral safety switch will not keep all motors from starting in gear if you turn them over by hand( crank manually), it just keeps the key switch or button from energizing the electric operated starter
