The housing on the powerhead that holds the bearings and seals for the Vertical shaft disintigrated, still holding bearings and seals, but it used to be about 4" long. Motor was setting up in storage and is seems that corrossion between shaft and housing was jamming the shaft. Housing broke apart when I forcibly removed lower unit.
1) Can I leave it alone and use it?
2) Piece does not come free, looks like I will need to loosen motor block halves. Can I just loosen bolts 1/2 turn and not break the seal?
Please advise.
Please advise.
