I have a 2006 F60TLR with 225 hours on the motor.
I have an issue where the motor is shutting down at low speed with air in the line.
I have replaced the Fuel line, primer ball and engine fuel line connector.
The tank end is a barb.
The tank is a 20 Gallon plastic that was cleaned and inspected 6 months ago.
I have confirmed that the pickup tube is good and have removed the check valve at the tank.
I also bypassed my external fuel filter water separator.
I am seeing the primer ball get soft whenever the motor is running and have seen air in the fuel filter on the rear of the motor.
Should I replace the fuel pump, it seems to be working and when I replace the inline strainer on the motor it sprays a little fuel.
Thank you so much for your information.
Tom in Port Charlotte.
