Originally posted by TownsendsFJR1300
View Post
F60tlr Air in Fuel Line
Ok, 10 PSI, about the same used to check if a lower unit unit is leaking or not, again, spray with soapy water and watch for bubbles..Originally posted by 99yam40 View Post15 would probably pop a primer bulb and the check valves may not let if get back to the tank
Bubbles are easier to see and as bad as his is leaking, it shouldn't be hard to find.
Also worth mentioning (as it happened to me), the Yamaha fuel filter under the cowl. As the plastic cup likes to expand with ethanol, make sure it IS fully seated on the main mount/o-ring.Scott
