Shift Positioning Sensor placed neutral to close to reverse on actuator can shift in and out of reverse. Actuator will not travel far enough to reach forward gears on its own. Must move linkage manually. SPS returns actuator to the incorrect neutral on command. The question: how do I reposition neutral on shift actuator?
2007 250 Will Not Shift to FORWARD
I do not recognize that model code.
does this model use a shift cable OR is the shifting done by an electronic actuator?
if it uses an actuator there ARE NO adjustments.
you may have some stuck bushings.
when shifted and it kicks baack to N, do you get an alarm?
thank you for your help gentlemen i will travel to the boat in the next couple off months. i think i now have enough knowledge to make a diagnosis i will contact you when i know whats wrong .ps i hope it is 2400 i was quoted 3200 in august when shift started to malfunction .
Originally posted by ECGOERES View Postthank you for your help gentlemen i will travel to the boat in the next couple off months. i think i now have enough knowledge to make a diagnosis i will contact you when i know whats wrong .ps i hope it is 2400 i was quoted 3200 in august when shift started to malfunction .
6AW-4820A-10-00 ACTUATOR UNIT
Originally posted by boscoe99 View PostAnd it is not considered a repairable either!
This is a remove and replace world.
Boscoe - you have some aircraft experience I believe. It seems there are many of these sorts of things on planes, especially larger ones. What do they do when time to replace? Scrap? Bet there are some shops that could figure these out. May be cheaper to replace when all said and done.
Originally posted by pstephens46 View PostSend it to Fairdeal. Let him tinker with it.
Now if it is an aircraft actuator repair place, the repair cost will probably exceed the price of the new marine unit. If that were an airworthy actuator certified for use on a Boeing it would probably be in the tens of thousands of dollars for a new one.
Â
