Alarm started making a non solid tone and had issue with power trim and tilt as I was in shallow water. The engine had a solid stream and was pumping water. I got to dock and shut motor off to unload my crabs when I went to start motor I have nothing no trim/tilt and no sounds from key being turned on. I have another throttle and harness I plugged it in to see if that is it and still nothing. It side mount control and harness is wired into it. the key switch dose feel kinda tight. was going to remove the back plate of controls to check for grimm or build up but didn't have the proper phillips head and the screws are soaking as we speak an ideas or help is appreciated.
