Greetings.. I bought Key West 1720cc in 06 but I think the motor is a 05 F90TLRD..On the right side there is a sticker with "mfg 05/04" on it so I'm not 100% sure.. My boat was put up for a few months with the motor up on that flip down lever.. I hooked up the battery and the trim motor wouldn't go down..I let it down with the release screw and when it was down the switch worked again
so I ran it all the way up and back down and there it stays..Dead again and relay clicking.
. I did some research and found that on the relay the blue is the up wire and the green is down. I disconnected both and put the blue wire right on the verified hot/red nut and still it didn't go up so I presume the motor is bad or likely the brushes are stuck.. The other problem is I tested the relay outputs while pushing the button and I get battery voltage out the bottom/green wire screw but nothing out the top/blue wire "up"screw.. I can only think the relay is bad as well as the motor.. Is there more I should know here? Am I doing the right tests the right way? Thanks
