Originally posted by cpostis
View Post
Steering rod
Your very welcome.Originally posted by timsullivan View PostThank you Townsends
I usually give that fitting one squirt of grease maybe every other time out. It (the cable) will NOT seize after installing that. They sent me a spare inside o-ring (which I still have new in its packaging)..
I did splurge and ONLY use Yamaha branded grease on all engine fittings as the cheaper stuff tended to gum up (especially the steering fitting-with grease coming out the top and bottom)Scott
Nice product! But, if you only occasionally use you boat, be sure to exercise the steering on a regular basis. Even the best grease and o-rings can get hard if sitting stagnant.Originally posted by TownsendsFJR1300 View PostElmer? Huh?
"Bill
1997 204 Angler, center console with an '06 Yamaha F150."
Scott, Elmer Bill, WTH?Chuck,
I used the Wally World stuff from 1997 till maybe two years ago..
Never a problem with the steering as it'd force the grease out. The inner seal in that "end" is always inside grease, so I gather that all that grease helped its life span.
Now, when I changed over to the the Yamaha grease for the ENGINE STEERING ITSELF (grease fitting in the mid section), it took awhile for new grease to come out ALL ends(not just the one that was fully clear). That gets a squirt of grease after every outing..Scott
