Hey im new to the forum, tried searching for this problem, havent seen anything. So i was pulling the lower unit, in the process, the lower shift rod nut was siezed, so naturally it broke in the lower unit. Has anyone ever fixed this? Im going to be replacing the seals in the lower unit and the water pump anyway, but any input would be greatly appreciated. Also, the lock pin that the impeller goes over on the shaft will not come out, keeping me from being able to pull the whole water pump, any ideas? Thank you all in advance.
1994 Yamaha 25 broken shift rod
