I need to replace the tilt/trim motor on my outboard. Is it possible to remove the trim motor and replace it, while leaving the tilt assembly attached to the outboard. From the diagrams, it appears that I could remove the upper pin from the ram, or the lower pin from the hydraulic pump assembly and swing the assembly to gain access to all 4 screws from the trim motor.
Thanks in advance for comments and help.
Gary
Gary
