hey yall, I'm very new to boating and I'm really hoping to get some help here. I purchased a boat with an 04 Yamaha 4 cylinder 4 stroke 50 horse which I believe is an f50? the previous owner had loads of receipts from gauge work to carb rebuilds to the prop and cover. He said second run of the year it just wouldn't start and that is how I purchased it. It has the safety switch attached, new gas, fuel lines, primer bulb, fuel from fuel pump, spark, 170psi compression in neutral and a new battery. Can anyone lead me to the next step here, or am I bound to go to the Yamaha dealer? thanks in advance!
2004 f50 no start
If its sat for any lenth of time, the carb(s) are very likely clogged up.
It doesn't take a month for un-treated ethonol to goo it up..
If your somewhat mechanically inclined, you can pull the carbs, the float bowls and clean the jets.
There should also be a tag with a model # like F40xt..
That will allow you to bring up the carb parts fisch
and see where their located, etc...
A shop manual wouldn't hurt and some knowledge of carbs would be helpful..
IE: http://www.boats.net/parts/search/Ya...TOR/parts.htmlLast edited by TownsendsFJR1300; 07-22-2016, 07:14 PM.Scott
Originally posted by boscoe99 View PostIs it a no crank or a no start issue. I can't tell.Scott
Originally posted by rammunition361 View Postno start. itll crank all day but it wont even hit a lick. I cant see it being a carb problem, I drained the bowls and I would think it would at least hick up
My money, the carbs are gooed up.Scott
Originally posted by TownsendsFJR1300 View Post170 PSI compression, it should be cranking, I suspect no start..
But now we know. I guess.
Originally posted by rammunition361 View Postnot quite sure where to spray starting fluid? cant readily see an air filter housing. remember I'm new lol
Inside part #24, that's the air intake (sometime referred to as the air filter but there's no filter). Follow the carbs back to where they would be getting air..
2004 F40EJRC Yamaha Outboard INTAKE Diagram and Parts
Agreed with Boscoe.. ^^^^
If it kicks with the spritz, you know its in the fuel system.
Respectfully, I suspect even that, you'll possibly be in way over your head.Last edited by TownsendsFJR1300; 07-22-2016, 07:43 PM.Scott
Originally posted by boscoe99 View PostTake it to the mechanic please. See if he will let you look over his shoulder for a bit of engine familiarization.
Originally posted by rammunition361 View Postmaybe, ive been a mechanic on passenger cars and heavy equipment for some time. Just trying to save a buck, thanks for your time sir
Not a problem saving some bucks and learning, soooo, continue on.
Spritz and see what happens.
I gather you've been inside some float carburetors?Scott
yes I have, I will try the starting fluid, I do know the pump is refilling the bowls but I will probably take to the marina for repair if I have to remove the carbs, unsure on the timing of the four
ÂÂÂÂÂÂ
