I recently purchased a lightly used under 200 hrs VMAX 150 2001 outboard and boat. It always fires up right away when I first place it in the water. Over the past couple weekends after I run it and shut it off ,when I go to restart it it's a bear. It is getting progressively worse. It sounds to me like it isn't getting fuel.
This last weekend after I ran across the lake from the landing to a fishing spot I tried to restart it and it wouldn't go. I pulled the fuel filter and everything looked good. I pumped he bulb and it would get hard but then slowly soften over time. I motored back to the landing with the electric and pulled the boat out of the water. There was some black slurry with flakes of carbon coming out of the exhaust I noticed when I trimmed it up. In the parking lot I turned the key and it backfired real loud.
When I got home I put the ear muffs on the motor and it started it up and it fired up after the first or second try. Seemed to idle ok.
Is this a bad fuel pump issue or any idea what the problem could be?
Thanks for the help
Thanks for the help
