My f150 will hesitate when stone cold. Such as backing off trailer at ramp. Not when warm however.
F150 Stalls when put in gear
Just curious(not recommending)could the idle be slightly increased by just drilling small hole in each of the throttle plates without touching anything or readjusting sensors. Once again..thinking to myself appreciate your thoughts ??
Originally posted by Nautical View PostJust curious(not recommending)could the idle be slightly increased by just drilling small hole in each of the throttle plates without touching anything or readjusting sensors. Once again..thinking to myself appreciate your thoughts ??
But wouldn't it be easier to simply crack the throttle valves open using on screw driver instead of drilling four throttle valves and then having to clean up the motor to ensure no swarf or swill got ingesting into the intake?
Not thinking of doing it and of course a lot easy to open the throttle up a bit mechanically , but I was just theorizing as I said in my statement. Merely a thought if someone did not want to mess with changing original engine sensor settings .
there is a new procedure to follow when setting everything, it is different than the original in the early manuals.
it keeps the motor from stalling when shifting into gear from what I heard/read.
if you do not have a problem you do not have to change anything, but if you are having the stalling problem then just follow the new procedure when setting.
no reason to start destroying parts to see if you can get it corrected
Originally posted by 99yam40 View Postdrilling holes in things destroys them,
where they do not function as they should from the factory
Originally posted by Nautical View PostSir, this method is used commonly in the automotive tuning world for idle control with specific engine tuning parameters..Will not destroy the throttle body as you suggest.. I think Holley makes them with drilled holes for many applications.Can always be soldered closed if necessary. In closing I agree with Rod and Boscoe that cracking and adjusting is a lot simpler, I merely posed the thought as a theory for discussion. I apologize if it was interpreted as a better fix for the stalling/low idle than what Yamaha servicing specifies in previous threads
But, there is a newer way to fix the low idle issue (on the F150), so really there's no reason to modify anything.
I don't know how the master tech fixed mine, I believe it was before the updated procedure came out, but I have no issues now...
Idea's are always welcome as far as I'm concerned...Scott
Originally posted by Nautical View PostI apologize if it was interpreted as a better fix for the stalling/low idle than what Yamaha servicing specifies in previous threads
To be honest when I first read about the F150 idling issue, and reading about the solution "RODBOLT" came up with and the procedures and reasons why he did what he did, it reminded me of the same reasons and results of what we did back in the day to the LS1 engines. The only difference is, the F150 has a nice easy screw to adjust to crack open the throttle plates.
But you never know, in the next revamped "NEW AND IMPROVED" release of the F150, Yamaha might incorporate holes in the plates to fully resolve the idle issue so no adjustment is needed in future and all F150's will idle happily.
We can only but dream at this stage
Its amazing how over time there has been big improvements in sensor, injector and ECM component technology..... but have still noticed the odd manufacturer still using old technology in todays motors.... some times with that it gives you the feeling of being a bit "ripped off" so to speak, but oh well them's the breaks
Cheers
Scotty
Originally posted by TownsendsFJR1300 View PostGlad its better but it still shouldn't have any hesitation...
i can either accelerate slow or nail it from idle with no hesitation...
You may try some RingFree (if not already).
I had a running issue at 5300 RPM's and new spark plugs fixed that
(with low hours on the engine)..
Originally posted by BigRich123 View PostImmediately after adding the Ringfree it now stumbles occasionally after turning it on. The rpms will hover around 500 before coming up to 700.
Give it a couple of good runs and dissolve all the carp you loosened up..Last edited by TownsendsFJR1300; 08-14-2016, 01:42 PM.Scott
ÂÂÂ
