Hello everyone I just picked up a deal on a 2001 SX200TXR 0X66 Salt Water Series motor on a Hurricane Deck boat. The guy I bought the boat from told me the oil transfer pump is bad. He said once the oil gets down low the alarm comes on and the only way to fill it up is with the manual override switch. Today I took a crack at trying to figure it out and he is what I found and I am hoping someone can help point me in the right direction.
1. With the key on the manual override switch works and oil pumps into the tank on the motor.
2. I hooked a battery straight to the pump and disconnected the oil line at the tank and verified that the pump works.
3. I performed a continuity test on the oil level sensor/sender switch according to the manual and it all passed.
So far according to what I tested I know the pump is good the switch is good. My next test is going to be lowering the oil level on the engine tank and see if the pump gets activated and actually pumps oil. I will say with the key on and I pull the sender out the alarm goes off but the pump does not activate. I guess my biggest question is what is the proper way to test the oil pump and sending unit in automatic mode and does the engine need to be running? I have also read several other places online and they said to replace the inline oil filter and I plan on doing that once I figure out why the pump is not turning on. I also visually inspected all the wiring harnesses and everything looked good. Any help or tips will be greatly appreciated. I am new to Yamaha motors and so far I like what I have read and seen.
