Is there a bench test for Fuel Pump Driver Isolator? Getting signal from the E.C.U. on a frequency test in the blue with red stripe for 5 seconds at key on but Pumps won't stop at all after key on and running? Guessing they are grounding out inside the Isolator but can't find much info about this in the service manual.
Also was wondering if the voltage is supposed to be regulated to the pumps? L.P. pump running at around 6.5v H.P. at 11.7v battery at 12.6v at the time of the test and only key on not a running test. Any help would be appreciated!
