aha! happy ending
well, different - but more satisfying results this time around.
I must have been using a "bad" test lead this morning - or repeatedly missed making good connections.
Anyway, I just went back to the motor to take a stab at that "grounding both" theory.
Set up test leads as follows:
12V+ to R/Y
ground to B
ground to B/W
voltmeter to L/W
other voltmeter lead to 12V+
My plan was to turn on the battery switch, then watch the voltmeter while I also grounded L/R.
But when I came back to the engine after turning on the power, the meter was already showing 12V -
with just four leads connected to the driver!
So: grounding the B/W wire also grounds the L/W wire!
(its hard to see the black test lead connected to the black wire in the plug
the white lead is 12v to the red/yellow wire
the yellow lead is also ground, to the black/white wire
the green connects the meter to blue/white)
While I was at it, I moveded the leads and confirmed what I saw this morning:
grounding L/R also grounds L
so the mystery is solved;
the ECM "turns on" the LP pump by grounding the black/white wire
and "turns on" the HP pump by grounding the blue/red wire
12V+ to R/Y
ground to B
ground to B/W
voltmeter to L/W
