I'm setting the timing mechanically just like the factory service manual describes in the "Periodic Maintenance" section and I'll have some questions as I go along.
The first question concerns the Adjust length of full advanced stopper (1), the specs call for the length to be 26mm, but the drawing is not clear from where the measurement is taken, it looks like it is from about half way from the screw mount in the drawing, but if I use that point then the magneto control link (3) is not long enough to reach the mark, it can't be adjusted any longer. I therefore, set the full advanced stopper at 26mm measuring from the base of the screw mount to the tip. Is that correct?
