Originally posted by panasonic
View Post
Ok, did a little research. I assume you are referring to the friction from plug to pin. I didn't know it had a name.
I'm not quite sure how I would do that in this case. That particular plug has 26 reasonably condensed plugs. They appear to be water-proof/resistant, so I'm not sure how I would pull a given wire from the plug. I'm open to ideas!
I actually did have that issue on the bullet connector (blue wire) to the emergency switch. It was so loose I'm amazed the vibration of the engine running didn't knock it loose. Found that when I was tracing, checking, and confirming grounds/continuity/resistance/etc.
