In reference to lower units. Say a gear is 2:1 versus 1.75:1. I was thinking 2:1 was 1 turn of crank for 2 turns of prop shaft. Is that correct or ass backwards?
Somebody splain gear ratios
It's the ratio of engineOriginally posted by pstephens46 View PostIn reference to lower units. Say a gear is 2:1 versus 1.75:1. I was thinking 2:1 was 1 turn of crank for 2 turns of prop shaft. Is that correct or ass backwards?
rop. Same basic idea as found in truck rear ends.
Edit: I don't know where that smile thing came from... was supposed to be engine "colon" propLast edited by DennisG01; 10-27-2023, 10:52 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Bass ackwards.
Two turns of the crank shaft equals one turn of the propeller shaft. Or 1.75 turns of the crank shaft equals one turn of the propeller shaft.
Holds true for cars/ trucks unless they are in over drive. In which case the crank shaft turns slower.
No outboard motor uses an overdrive configuration.
Interesting. Always figgered those prop shafts spun faster than motor.Originally posted by boscoe99 View PostBass ackwards.
