fuel pressure at 38.
Jan 1st. cold
Diagnosis Record,
,Total hours of operation,43,
,Code,Item,Occurred,
,28,Shift position switch,5.3,
Engine Monitor,
,Monitor Item,Result,Unit,
,Engine speed,0,r/min,
,Intake pressure,95.09,kPa,
,Intake pressure,28.15,inHg,
,Atmospheric pressure,951.0,hPa,
,Atmospheric pressure,28.1,inHg,
,Ignition timing,-,deg,
,Battery voltage (12-16),12.50,V,
,TPS voltage (0.5-4.5),0.718,V,
,Throttle valve opening (0-90),0.5,deg,
,ISC valve opening,65,%,
,Fuel injection duration,0.00,ms,
,Water temperature (below 90),8.0,°C,
,Water temperature (below 194),46.4,°F,
,Intake temperature (below 70),9.2,°C,
,Intake temperature (below 158),48.6,°F,
,Engine stop lanyard switch,OFF,,
,Shift position switch,ON,,
,Oil press switch,ON,,
,Dual engine system switch,OFF,,
Jan 2nd first start
Engine Monitor,
,Engine speed,781,r/min,
,Intake pressure,41.50,kPa,
,Intake pressure,12.17,inHg,
,Ignition timing,ATDC 4,deg,
,Battery voltage (12-16),14.00,V,
,TPS voltage (0.5-4.5),0.728,V,
,Throttle valve opening (0-90),0.7,deg,
,ISC valve opening,58,%,
,Fuel injection duration,2.05,ms,
,Water temperature (below 90),45.0,°C,
,Water temperature (below 194),113.0,°F,
,Intake temperature (below 70),15.0,°C,
,Intake temperature (below 158),59.0,°F,
,Oil press switch,OFF,,
Jan 2nd warming up after numerous stalls
Engine Monitor,
,Engine speed,765,r/min,
,Intake pressure,40.03,kPa,
,Intake pressure,11.73,inHg,
,Battery voltage (12-16),13.90,V,
,TPS voltage (0.5-4.5),0.723,V,
,ISC valve opening,53,%,
,Fuel injection duration,2.00,ms,
,Water temperature (below 90),50.0,°C,
,Water temperature (below 194),122.0,°F,
,Intake temperature (below 70),16.1,°C,
,Intake temperature (below 158),61.0,°F,
I also ran the active test and rpms went to around 1500 and at first the engine surged up and down like it wanted to stall. Run test 2 more times and it appeared to ramp up and down ok.
Jan 1st. cold
Diagnosis Record,
Engine Monitor,
Jan 2nd first start
Engine Monitor,
Engine Monitor,
