Hello Everyone,
I have posted about this issue in the past. unfortunately i do not have a yamaha dealer in the area. But here is the issue and what i have noticed.
At first start engine idles ok then may die. As i leave harbor the engine will just shut off. no sputter or surging at all. Then restart fine and continue to the open water. After a short period of this then everthing is ok and not one problem the remander of the day.
Today i when i made it to the open water i hit full throttle a hoped it would stay running ok. The rpm will rise and then drop to zero and shut off. On the second attempt I was attempting to put into netural and had hit the trim down button and the rpms came back up. So i experminted. As long as i kept the trim down activated the motor would not shut off. The second i let off the switch it would want to shut off. The as always after a short period 15-20 minutes everything ok for the remander of the day.
The list is long of replacement parts as i mentioned before a brief list that the first mechanic replaced that has since moved away.
ECM
IAC TPS sensor
Fuel pressure regulator
High and low fuel pumps and hoses and primer ball.
VST cleaned and new filter screen. pressure 39 psi
Filter between ball and low pressure pump.
Key switch and kill switch assembly
Therostat and cooling sensor.
sensor on air box.
two harness on engine.
harness to remote box.
main relay.
Also ran on aux fuel tank.
Thanks for any input.
Dean
ECM
IAC TPS sensor
sensor on air box.
main relay.
Dean
