Faulty wiring, a bad connection or a faulty CDI would be my best guess.
Ox66 Fuel Issue
Wiring isn’t showing anything upon inspection of connectors but I’ll bypass one section at a time to make sure. Since I have a second engine on the port side can I swap the CDI unit to see if that is the issue? Only difference I’d prop rotation ?Looks like the 150 and 200 share the same CDI for years . Should be some used ones available, the price for a new one is crazy.
The pump basically runs or it doesn't - it doesn't change RPM's otherwise the injectors wouldn't fire properly. The control of the amount of fuel being shot into the engine comes from the duration that the injectors are opened (con*****ed by the computer).Originally posted by 99yam40 View PostI would think at low RPMs the pump does not need to run a full RPM
Well, I suppose technically a pump could run at lower RPM, but then it would be failing.
Last edited by DennisG01; 09-27-2023, 01:01 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
would the resister not lower the voltage ?Originally posted by DennisG01 View Post
I may not be the best one to explain this clearly enough - maybe someone else can (most likely!) do a better job.Originally posted by 99yam40 View Post
Yes, a resistor would lower voltage, but that's not "really" what it's being used for. Besides, it is not a "variable" resistor so it can't change it's resistance value.
There should always be full battery voltage at the HP pump.
The "RPM" that was mentioned earlier in the post is in reference to engine RPM, not pump RPM... in case that's where the confusion lies.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
To reduce the current flow through the pump. Less current results in less temperature rise in the fuel.Originally posted by ttles714 View PostI am interested and following this post ..... Am I right in understanding that the HPFP is grounded thru a resister ?????? Blow 1200 rpm but above that it is grounded by the CDI ???? Why a resister ????
To lower the speed of the pump when it is not needed for the pump to provide a greater volume of fuel to the injectors.
It is the fuel pressure regulator that is con*****ing the fuel pressure to the injectors. Not the speed of the pump. Pressure that varies with the intake manifold pressure.Originally posted by ttles714 View PostI would think that the pump would need steady RPM's to maintain pressure to the injectors ....still trying to understand all this
The fuel pressure from the regulator is higher when the manifold pressure is higher (throttle opened) and lower when the manifold pressure is lower (throttle retarded).
At all times the fuel pump can provide more fuel than is ever needed by the motor. The pressure regulator sends excess fuel that is not needed by the injectors back to the vapor separator tank.
OK then I was correct, the resister does lower the voltage and the speed of the pump when the motor is running at low RPM.Originally posted by boscoe99 View Post
thanks Boscoe
And I stand corrected... and learned something new that I thought I knew "correctly" for many years!Originally posted by 99yam40 View Post
thanks Boscoe
