Ok guys I need a little help. I’ll give you the details and then I’m all ears.
2000 ox66 LX150 TXRZ. Doesn’t want to start easily but give it a mist of mixed gas or anything else and fires right up. All three fuel pumps and filters are new. Fuel pressure at idle is 38 psi. VST tank is full, clean and refills normally. Will idle for hours if you let it but seems to be a little rich with oil compared to its SX 150 TXRZ brother. Problem starts when you give it any fuel. Revs up for a second to about 1500 and dies. Will restart immediately after it warms up.Fuel pressure drops off to nothing instantly when you give it the gas and the voltage to the pump also goes away. If you use a jumper on the HP pump ground side to engine ground the motor stays running and doesn’t stall out. No immediate alarms when the switch is turned on. Both thermostats and temperature switches are new, engine mounted oil tank is full and switch is new. The remote oil tank pump doesn’t appear to be working is the only thing I can find wrong initially with the setup. What am I missing?
