2000 OX66
2 stroke ]
fuel injected
250 hp
don/t know model number
ran good , a week of rain here in fl ran ike crap ,
Water separator cap filled with water - How it got in ( don't know ) but getting new fill with base , plenty of 5200 - water deflector around fill , Keeping it covered
drained fuel from tank into a portable 6 gallon tank ( only had 5 gallons ) cleaned tank
installing new separator filter
no water in primary engine gas filter but installing new
Drained VST tank , no water
Prior too install priming 2 filters with fuel
VST tank had fair amount of fuel - will pumping fuel ball and cranking engine fill VST tank ?
, Sharder valve on VST , should i keep opening it removing air until fuel comes out
anything else I should do ? SEA FOAM or carb fuel injector cleaner ?
thanks
2 stroke ]
fuel injected
250 hp
thanks
