Hi all, I'm wondering if any of this seems familiar to anyone or any recommendations on places to start looking... or a direction to look in...
-- 2001 SX250HP OX66.
Problem:
-- Can run all day long at mid 3,000RPM to low 4,000 RPM range with no issues. Engine runs like a champ.
-- When going WOT, after 10 to 30 seconds, it will start to lose power - and it loses power rather quickly
-- If I back off to a lower RPM range, all is fine
-- If I hold the higher RPM, power will continue to drop lower and lower
-- I did not try holding the throttle handle WOT so long as to see if it would eventually stall out
Notes:
-- Fuel is clean (use Startron and RingFree religiously). Collected fuel from the VST drain and it was clean/good.
-- VST hi-pressure pump filter is clean
-- Spark plugs appear all similar in color - dark brown, slightly black
-- Fuel injectors were professionally cleaned less than 100 hours ago.
It will be about a month till I get back to the boat, but was hoping to get some recommedations?
-- I plan on running with a fuel pressure gauge hooked up to start with... Trying to narrow things down.
Problem:
Notes:
