Oh... the HP pump tested at .6 Ohms across the motor leads. This was after a 5 minute idle from the mooring to the dock.
Losing Power At High RPM
Yes, it does (just trying to document as much as I can). It's in the boat and I'm in the cabin right now, but I believe it's something like 5 or 6 ohms... but I read that after running for a bit, it often lowers. Either way, it's low resistance so the pump (from this test, anyways) seems good. High resistance would be a problem.Originally posted by 99yam40 View Postdoes your manual give Ohm specs?
I just find it hard to believe that a pump could (consistently) be "flaky" where it only fails at high RPM's. I just don't think the pump cares about higher RPM? The FLOW through the pump can increase, but the PSI stays the same. Well, at least, that's wher emy head is on this at this point.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
If the lift pumps cannot keep up with the flow needed to keep the VST full.
either they need to be replaced or maybe the Bypass pressure regulator is dumping too much fuel.
But I am not sure there is a recirculation set up for the lift pumps.
also is there a fuel cooler on this motor that might be not getting the water flow it needs to keep the fuel from vaporizing under the pressure and flow needed at high RPMs.
Just some random thoughts I had
All good thoughts - and appreaciate them all. You're correct - no recicirculation. No, there is no fuel cooler.
BUT... I played around with the top LP pump and it started leaking out of one of the screw holes. This area should NOT leak as it's sealed off from the gas. I took the LP pump apart (again) and there are no rips or tears in any of the gaskets. But they must have lost elasticity. No combination of various tightening torque eliminated the leak.
Now the engine ran out of fuel at idle. I drained the VST immediately and only about an ounce or two came out. Nowhere near where it should be. LP pump must be letting in air when running - and was probably the reason all along - even though there was no visible leak (not even from behind the pump).
I put a new LP pump on it and we're back in business - ran WOT with absolutely no issues. I'll replace the other two at the beginning of next season.
I'm a happy boater!
Good idea!Originally posted by 99yam40 View PostGood to here.
A clear piece of tubing temporarily put in place right after the pumps might show air bubbles if you run into this again.
Interesting... the "test" that I found on You-Tube by a professional that said to loosen the LP pump a bit from the block? It turns out that is NOT a definitive test like he said. I'm glad that I found that test, though, as I still think it has merit. It's just not the "be all, end all" of tests.
I think if I had my Mity Vac with me, that may shown the LP pump to be bad. If I remember, I'll put the Mity Vac on the bad LP pump when I get home and see what happens.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I had this exact same problem on my 225VX. One of the lift pumps had a small tear in the diaphragm. This resulted in a very small fuel leak that wasn't easily detectable. My boat would run great for 30 seconds, then the motor would shut off. Sometimes it would sputter back to idle, but most times it would just die. I could easily restart it and keep going. It would run 4000 RPM all day, but anything over that would kill the motor. The lift pump that was leaking was degrading the amount of fuel being pushed into the VST. Above 4000RPM, the motor was draining the VST. When all the fuel was drained, it died. I couldn't find just the diaphragm, but I got 3 brand new lift pumps from Amazon for $100. Replaced all 3 and haven' had that issue again. Those same 3 lift pumps now cost $130 from Amazon. I guess inflation is getting to everything. That said, given my motor's propensity for chewing up these low pressure lift pumps, I'm considering buying 3 more just to have on hand in the future.
I've been contemplating switching to an electric fuel pump and making block-off plates for the block where the LP pumps would have been. Been contemplating that for about 5 years, nowOriginally posted by Aggiedave View PostI had this exact same problem on my 225VX. One of the lift pumps had a small tear in the diaphragm. This resulted in a very small fuel leak that wasn't easily detectable. My boat would run great for 30 seconds, then the motor would shut off. Sometimes it would sputter back to idle, but most times it would just die. I could easily restart it and keep going. It would run 4000 RPM all day, but anything over that would kill the motor. The lift pump that was leaking was degrading the amount of fuel being pushed into the VST. Above 4000RPM, the motor was draining the VST. When all the fuel was drained, it died. I couldn't find just the diaphragm, but I got 3 brand new lift pumps from Amazon for $100. Replaced all 3 and haven' had that issue again. Those same 3 lift pumps now cost $130 from Amazon. I guess inflation is getting to everything. That said, given my motor's propensity for chewing up these low pressure lift pumps, I'm considering buying 3 more just to have on hand in the future.
