I have no response when I turn the ignition key. I checked the solenoid and it will function if I apply 12 V from the positive side of the battery to the solenoid. The engine will turn over.
I checked the voltage from the brown wire that connects to the solenoid and it shows 0.4 V when the key is turned. The ground from the solenoid is good. I also replaced the solenoid with a spare new one and bench tested both units. They function correctly and produce a good solid “ click”. I’m suspecting the key switch, but anyone have any other thoughts? Thanks.
