Working my way thru getting too know this engine ,
OB is new too me going from IOs
OX 66
around year 2001
2 stroke
250 hp
fuel injected
Used boat few times and noticed after use when I trim up motor oil comes out , Not a lot , maybe 1 2 ( max ) caps full , Wipe it dry ,
Oil container is up too fiull line , Cap tight and no residue of oil coming thru anyplace .
Viewing areas of engine no indication of oil
small amount base of motor
I clean with brake cleaner and searching for oil marking but not noticing
R there hoses I should be checking ,
As I stated only a very small amount , but its bugging me
IS this common with 2 stroke ?
ALSO , trim and tilt supports , - Just noticed best too use some sort of support placed over trim & tilt then lower engine , not using the support with moveable bracket supplied by yamaha .
I see some use only one ?? would think two would be best ?
thanks
OX 66
around year 2001
2 stroke
250 hp
fuel injected
thanks
