I need to remove the bottom pin holding the trim tilt cylinder. Need to get behind it to remove fowling and repaint. The pin seems to be pressed in? How is it removed? with a special Yamaha press? Part #31 & #32 in the diagram. 2018 115hp any and all help appreciated. thanks
Remove bottom pin on 115hp trim tilt
pic is too small to see,
which of these 6 2018 115s is your motor so others can look up diagrams for it?
Yamaha - Outboard - 115HP OEM Parts | Boats.net
Here is a link to the photo Yamaha Outboard 115HP OEM Parts Diagram for Bracket 1 | Boats.net
My computer skills are limited, the boat is across town, so not positive this is the exact model # but all of the 2018's look the same.
"looks like you just need to remover both #34s & #33s,I've hit it a few times with my DeadBlow hammer and no movement yet, I fear breaking the bracket (items #1 & #2 in the diagram.
and then put a longer bolt in one side and hit or push it out the other side.
or rig up a slide hammer to screw into the bolt hole and pop it out with a slide hammer"
Originally posted by GoldToyBox View PostGot it! Had to make a simple puller and added some heat and it let loose with a big POW. for a second I thought the bracket broke!. Paint tomorrow and reassemble. GO FISHING!
can you post up a pic of the puller you rigged up, it may help others when they search for what to do
ÂÂÂ
