part of the link and sync is checking timing also to make sure it does stay in spec at idle ad WOT
a timing light will show you what the motor is doing with timing and it should show that you have good spark on all cylinders if you move the induction pick up to each plug wire
as was said different motors can have different number of magnets under the flywheel so pole or pulse settings can be according to the motor you have, but most old school 2 stroke outboards should use the same type of tach, just need to adjust the settings.
newer 4 strokes can get signals from the ECU and give lots more info to the tach
