Hey guys, I have a 70TLRC (freshwater) That i'm having what I think is an ECM problem..
Here is what's going on:
Engine starts and idles fine, throttle response is great when Not put into gear. When I leave the dock The engine doesn't seem to have full power, it will run 3 or 4 minutes then the BUZZER goes off and the engine retards and can only idle back at the dock, (anything above idle the engine sputters and shakes).. On One of the test runs it ran Prefect, came up on plane and the RPMs sounded great, only lasted about 30 seconds then back to running like the timing was electronically retarded. It's running around 170 degrees and over 13 Volts.
What I've Done:
New plugs, New Fuel Pump, New Fuel Filter, New Thermostat, New Voltage Regulator (Wasn't Charging), All 3 Carbs disassembled and Ultrasonic Cleaned, Timing checked, All 3 Coils Checked.
To me it feels like the ECM is failing and not letting the engine advance..
The Voltage gauge on the dash in not working but i'm showing 13+ at the battery when running
Any help from this point would be great!
Thanks in advance..
What I've Done:
Thanks in advance..
