OX 66 , - 250 Hp - 2 stroke
OB new too me ( always owing IOs ) problems will definitely educate me on this motor
changed external fuel filter ,cleaning clear bottom bowl , Looked clean
Primary filter ,- needed changing was dirty
Primed both with little fuel
Fired up
idled on hose ,
During week started ( always water running thru ) multiple times , letting it idle , few minutes , closing - never stalling ,
Other day ran about a minute then heard that sound sputtering , starving for fuel , DIED , - Just returned from few days out of town , back too boat , WHY ? , was running , maybe I hit kill switch clip ??
Nope , it seems good ,
Damn whats going on it was running ,
1/4 tank fuel , fuel sitting both filters bottom of bowls
Removed primary fuel filter ,maybe it was not sitting properly ? , looked good , seated properly
When I prime filter bowl should I see fuel entering while pumping ? ,
If I removed hose prior too primary and pump should I see fuel coming thru ?? I see no fuel pumping thru ?
air in line ? tank ? vent
Previous owner had shop clean VST box ,
Will check CO 2 sensor , clean
Will check fuses
heres were I dont know enough about this engine , coils , etc
Some thoughts and help is appreciated
Fired up
idled on hose ,
Will check fuses
