On a new to me 2005 225, I noticed that there is a very small pool of oil about the size of a quarter over a period of 2 weeks and is definitely coming from the lower unit drain plug. The screw/plug appears very tight. Is there an o ring or other seal behind this plug?
Slight leak drain plug
probably
sometimes referred to as a "crush washer"
the idea being that it seals well the first time it is installed
but not as well if re-used
same washer on upper and lower
if you leave the upper plug in
working quickly, you can remove the lower plug,
replace the washer and reinstall
without losing a significant amount
however, if it was me, with a "new to me" engine
unless I had real good assurance
that the gear lube was recently/appropriately changed
I would just drain & refill (w/new lube & washers of course)
that way I would stop the dripping
know that it was correctly filled with good lube
(and get some insight via examination of what comes out)
Usually there is only one gasket per plug. What is the complete model of the motor you are working on?
Sometimes a gasket gets stuck in the lower unit and if another is added to the plug it can result in a leak. Given the relatively cheap price of the gasket and the importance of that bugger it is not a bad idea to install a new one each time the plug is removed.
Too bad an O ring is not used and too bad that Yamaha does not use what I will refer to as the Evinrude lower unit oil system which has a reservoir that can be inspected to see if the lower unit needs to be serviced or not. Yamaha is slow to come up with modern technology. I bet if the EPA had not forced their hand they would still be using 6 or 8 carburetors.
Thanks Bosco99 and Fairdeal. this is a 2005 F225TXRD. The parts site shows two washers which is strange to me - maybe Yamaha was trying to save on parts sku's otherwise they could have used a thicker washer or an o ring.Originally posted by boscoe99 View PostUsually there is only one gasket per plug. What is the complete model of the motor you are working on?
Just as a side note, a dentist's pick tool is a great (and cheap) addition to your tool box. Sometimes the gaskets/seals can get stuck on there pretty good. Often you can pop them out with a screwdriver, but if any remains the pick tool works very well. I got a set of 5 at HF a few years ago - might have paid $5.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostJust as a side note, a dentist's pick tool is a great (and cheap) addition to your tool box. Sometimes the gaskets/seals can get stuck on there pretty good. Often you can pop them out with a screwdriver, but if any remains the pick tool works very well. I got a set of 5 at HF a few years ago - might have paid $5.
Also, if you do the oil change on a lift OVER THE open water, the gasket WILL FALL OUT as will the bolt, guaranteed..
