I have a 2006 VZ200TLR 200hp hpdi that has a serious spark plug carbon issue. Symptoms are with fresh set of bkr6eku ngk plugs runs great for about 10 minutes then starts missing and running bad. BLack smoke in exhaust like a carburated engine that is flooding. Pull all six plugs and they are coated with black soot. What I have done to this engine. Checked low pressure pumps for leaking into crank case. New electric fuel pump and float needle in vapor seperator. Had high pressure fuel pump and injectors gone through by injector rx. All new fuel filters. Compression and ignition all good. Indexed flywheel and Checked TDC on #1 cylinder and flywheel. Tried known good ecu and injector drivers. Checked reeds wich are fiber boysens and oil pump linkage. This motor does not have the o2 sensor. Thermostats are working correctly. What am I missing and what do I need to check from here? Would like rodbolt to chime in on this and let me know his thoughts.
2006 200hpdi imidiate all carbon spark plug issue
Four things will do that... Restricted exhaust... Late ignition timing.. Serious rich fuel mixture... Weak secondary spark....that's That !
[QUOTEtoo=Keithbaja;n238237]Four things will do that... Restricted exhaust... Late ignition timing.. Serious rich fuel mixture... Weak secondary spark....that's That ![/QUOTE]
Too cold spark plugs. 6 go to 7
Foul fuel
And bad injectors!Last edited by zenoahphobic; 04-26-2023, 12:28 AM.
Use Senior,, just touching on the most common basics. We can sit here all day and throw possibilitys
ÂÂÂÂÂÂÂ
