Hello I have a Yamaha 4hp 4 stroke that I just got from my father. I got it home and got the motor to run but I have one problem. Once at idle and I turn the choke off after about 30 seconds the motor wants to rev up if I pull the choke out and push it back in really quick it idles normal again for a bit and then revs back up has anyone seen this before or know what could cause this? Thank you in advance
yamaha f4msh
Thank you I’m going to try and find a air leak somewhere only because I have took the carbs apart and everything I have seen looks good so far to me Sharon thank you guysOriginally posted by ausnoelm View PostYep, blocked carb or an air leak, or fuel supply from tank, pretty common symptoms.
Any idea what year it may be? Should be a tags on the transom bracket with full model and year on it.
If it is the set up I am thinking about it has a u shaped plastic intake manifold with 3 or 4 gaskets on it. They all have to be in place and seated properly so there is no air leaks present.
