you will need to tilt the tank or whole boat so that it all gets to a corner you can stick the pipe into.
Once you pump out all you can, then use rags tied to something you can shove around in there to get the rest out.
and make sure you figure out where that water came from.
If you think it was pumped in, you can try to talk to the station people to see if they will help
