Have a F40 that sheared the driveshaft just below the mid shaft bushing. Had to drill and tap the end of the shaft and use a slide hammer to get it out. Seems as though the bushing might have caused the failure as we had a tough time getting the shaft through it. basically had to use a slide hammer all the way out. Now, i need to get the collar and bushing out so that I can replace them both. Thinking about using a bearing puller. Any ideas or tricks to get these things out? hoping that I don't have to pull the power head.
F40 sheared drive shaft
Looks like once the circlip is removed that spacer and needle bearing should fall out.. I don't see any "outer" bearing.
Capture.JPGScott
The bushing is not pressed in, but it's driven in with a special tool. Definitely tight so that it doesn't spin in the case. The bottom piece is plastic and should come out easily. Spoke to a tech and he said they cut them out with a hack saw blade. Cut through the bushing then use a screwdriver to bend it inward. Sometimes it takes several cuts to remove the entire bushing. Then, according to him, they leave them out.
ÂÂÂÂ
