you said it was a 2016 motor with 150 hours on it,
your owner's manual should give you info on how often to inspect and change parts by hours or by time .
so yes you should have seen the rust on the drive shaft going on before you had a leak to chase down.
but I will admit not many would look at the bottom of the oil pump because there is no way to look at that easily.
I am not sure how salt water would get up that high to get on those parts to cause them to rust
