This is from a 2016 90HP engine, less than 150 hours on it. Unacceptable in my opinion.
Yamaha low quality components
Originally posted by Keithbaja View PostThe older enduros two strokes were bullet proof
Originally posted by TONYG279 View PostThis is from a 2016 90HP engine, less than 150 hours on it. Unacceptable in my opinion.
Did you try to get a replacement from Yamaha?
Yeah I would not be happy about this driveshaft as well. Something not right there to me..bad batch of material or something.
Corrosion is typically not covered by a warranty.
Originally posted by TONYG279 View PostI just saw one with around 22 years of service and doesnt look remotely as corroded as mine.
Six year old motor. The lower unit should have been removed 5 if not 6 times by now. In which case the early onset of corrosion would have been noted. And action taken to remove the corrosion and swab the driveshaft down with marine water resistant grease.
I am doubting that happened.
how many times did you drop the lower unit in those 6 years and 150 hours of running in saltwater ,to inspect, clean, and lube that bare metal shaft?
ÂÂÂÂÂÂÂÂÂÂÂ
