I am hoping you might be able to point me in the right direction. I have a 2003 Yamaha 9.9hp outboard engine. I changed the impeller on the engine and when lowering the lower unit I moved the shifter into reverse to gain better access to the nut to disconnect. After replacing the impeller I reconnected the cable and connected the lower unit back to the engine. I then tried putting the engine back to neutral and it felt like it was stuck. I forced the shifter and broke what looks like a plastic piece that connects to a shaft.
Can you help me find this replacement part as well as give me instructions on how to get out of gear and get this part replaced.
Thanks,
Ken
Thanks,
Ken
