Recently noticed a very slow oil leak from the drain plug after an oil change. I got a new drain plug and washer, reinstalled. Same problem. So drained oil again, took a good look up at the threads and notice this tiny crack (in pic). Guessing maybe I had overtightened the drain plug at some point to cause this?
Thinking the options are to swap the oil pan...OR reinstall drain plug forever with some type of sealant and vacuum oil out for remainder of its service life?
Is this the right idea? What type of sealant would you guys use on the drain bolt threads? Thanks in advance for suggestions.
