Changed out the battery on my 1998 90hp Yamaha 2 stroke. Checked that all the wires were on and secure. Turned the key, nothing. Tilt trim is dead too.
No power to ignition, tilt trim, 90 hp 2 stroke
Make sure positives are on positive and negatives are on negative. Then look again for a missed wire that fell behidn the battery somewhere. I assume you have fuses on the side of the powerhead? Do you have any breakers/fuses on the boat that are between the battery and the engine?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
