Looking at the wiring diagrams, the R/R appears to have 2 outputs, RED and RED/YELLOW, The RED/YELLOW changes color to RED at a inline plug. Both have a 30 amp fuse and both eventually connect to the starting motor solenoid.
Is this just a redundant charging system for the starting motor battery?
Given the fact the RED wire from the R/R prior to the 30 amp fuse also supplies a 20 amp fuse to feed the main relay can it be removed from the solenoid and fed to the house batteries?
The diagram appears to have some sort of in line connection detail, however it does not look like a plug, any ideas as to what this actually is?
THANKS
THANKS
