Had a voltage drop issue for a few years. Threw a few bandaids at it and kept sailing. Got mad a couple weeks ago when I had to cancel a trip due to no start. Spent the rest of day stripping all 16 year old power cables from boat. Replacements on the way. Finally got around to dissection of old cables today. Hmmm.
Could this be an issue?
Originally posted by 99yam40 View Postare we looking at burnt off insulation
or 6 strands of the wire broken because someone nicked them when stripping the insulation to connect the lug?
Try a small can of that Liquid Electrical Tape….paint it on your cables and wires to protect from water and corrosion…..good stuff!
If you want to make a marine batt cable that lasts. Start with "ANCHOR" brand wire & Lugs. Fill lug with "OMC TRIPIE GUARD" grease. Use a lever type crimper and crimp twice. Finish up with heat shrink. If u used enough grease a tiny bit should squeeze out from the heat shrink. Also make sure you use the correct size cable. Its hard to go oversize. I use fisheries supply Seattle. Or worst marine if in a pinch. I recommend battery trays over boxes. Tighter & cleaner installation with no gassing issueLast edited by Keithbaja; 09-19-2021, 01:44 PM.
Originally posted by Keithbaja View PostIf you want to make a marine batt cable that lasts. Start with "ANCHOR" brand wire & Lugs. Fill lug with "OMC TRIPIE GUARD" grease. Use a lever type crimper and crimp twice. Finish up with heat shrink. If u used enough grease a tiny bit should squeeze out from the heat shrink. Also make sure you use the correct size cable. Its hard to go oversize. I use fisheries supply Seattle. Or worst marine if in a pinch. I recommend battery trays over boxes. Tighter & cleaner installation with no gassing issue
ÂÂÂÂÂÂÂÂÂ
