Hello,
First of all my SX200TXRX turns out to be a S200TXRX. The plate on the motor says SX but this has carbs. At any rate I replaced the water pumps as was advised by this forum and got the starboard engine fired up. The port engine's lower unit going back together took a couple of tries but it did go together without forcing it. It also fired up. The problem is it will not shift into fwd or reverse. I took the lower unit off and the motor linkage is fine. The shift cam assy does not budge. Ideas?
