Ran out about 8 miles at 4,000rpm into the bay with no issues until I got off the throttle to look for fish. Ran rough about a minute then cut off. Would not restart. Finally figured out it would run disengaged above 2,000 rpm. Manually throttled up at the motor with throttle arm off and got my kid to chunk it in gear. Made it back with no issues. Until the dock when we went to neutral it cut off after a bit.
Been through the gas side VST ,filters and injectors. Same result. If I open the throttle body and manually open the valve a little it fires right up. Got me thinking its the TPS pressure sensor. Trying to keep from from taking it to a shop but might have too. Any help or knowledge would be appreciated.
