Originally posted by zenoahphobic
View Post
Repaired cases, same thing we did (common as this cracking is also a common issue) is about $800.00.
When I pulled the carrier out, there was so much crap inside/corrosion.
Before re-assembly, it was spotless, ALL corrosion removed, coated with Zinc chromate (which it wasn't before) and coated with Yamaha's waterproof grease in the problem (corrosion prone areas).
That lower unit will last longer NOW, than the power head easily
